Debate y preguntas relacionadas con el curso Cableado práctico para deportes de motor - Nivel Club
I am doing as swap on my Toyota 86 and was following a similar wiring process as was used with the HPA V8 Toyota 86 (patch harness and independent engine harness).
I am running 2x Bosch 2 wire knock sensors however the existing body harness only has shielding on the Knock+ wire and not on the Knock-/ ground. The Emtron wiring diagrams show that the Knock+ and Knock- are shielded together, would it be an issue if I just shield the Knock+ wire?
I've attached a quick sketch to explain it a little better.
Thank you in advanced.
