Help with CLT connector
748 Vistas
I'm trying to find a connector for the coolant temperature sensor on a 90-93 1.6L Mazda Miata.
It looks like a TE Junior Power Connector with the key in a different spot. The only JPT connector I can find has the key in the middle, but this needs it offset.
In the attached picture, the green connector is the original - the one I need. The black connector is a JPT connector.
Any idea if anyone still makes this connector or where I can get it?
Thanks!
  • Los archivos adjuntos solo pueden ser descargados por miembros Gold de pago. Lea más sobre cómo hacerse miembro Gold aquí.
You might start here, and drill down into the various keying options to get the actual housing part number:
https://www.te.com/usa-en/product-282189-4.html
Hi David,
I've already spent the afternoon looking at TE's website. I've found housings with 4+ pins that have different key locations, but all the 2 pin housings I've found have it in the middle.
I'll look again in case I missed it - TE sure doesn't make it easy.
Thanks
Normalmente respondemos en un plazo de 12 horas (a menudo antes).
¿Tienes problemas con el sitio web?
¿O necesita contactarnos por algún otro motivo?
