Honda K20 coil on plug wire gauge
3323 Vistas
Hi
Will a 14 AWG spliced to 4x18AWG wire be ok to feed four Honda K20 coils? Is there any preference on the AWG of the trigger wires? Is 22 AWG sufficient for the triggers?
Thanks in advance
Rob
Yes, yes and yes.
Would need more info to give a more concise answer but in general those are going to be fine.
https://www.dodo-racing.com/ignition-coil-wiring-gauge-calculator/
Check out this calculator. He built it based on voltage drop and while it doesn't take into account any derating for conductor insulation temp rating, bundling or ambient temp, its conservative enough to get into a safe ball park
