Nissan CAS and Coil Pack Connector Pin
Debate y preguntas relacionadas con el curso Cableado práctico para deportes de motor - Nivel Club
3100 Vistas
Does anyone have a part numbre for the pins and wire seals that are used in SR20 CAS connectors or R35 Coil packs
https://www.efisolutions.com.au/4-pin-connector-grey-common-for-cas-igniter-some-a
Would like to repin and reuse these connectors but cant find just the pins and seals on their own.
I'm pretty sure it's a sumitomo 91 series connector. Google that and perhaps you can find the actual Sumitomo part number.
Other sources:
Here is the connector kit (individual parts listed under the associated and mating parts tab):
https://www.bmotorsports.com/shop/product_info.php/products_id/4129
Terminals:
https://www.bmotorsports.com/shop/product_info.php/products_id/2180
https://www.bmotorsports.com/shop/product_info.php/products_id/4222
Seals:
https://www.bmotorsports.com/shop/product_info.php/products_id/2181
I suggest you buy the complete kit, to make sure the terminals exactly match the housing.
