power supply and relays
2394 Vistas
hi everyone,
I have a novice question(s):
for the enabled power relay in the diagram provided in the course are we using 1 relay only that will output to the ign coils, injectors, wideband, etc or do we have separate relays for each of the components which require power?
Hi,
I am runing one relay for my coils injectors and other components that require switched 12v. The Fuel Pump runs a seperate relay as well as the Fans. Everything works fine but I plan to upgrade my harness and add extra relays to distribute the power.
Thanks
Alsabaa
Thanks Alsabaa!
you have cleared this up for me. I will probably go with a relay each for the fuel pump, coolant fans, ignition coils and injectors. i most likely will be using a link G4+ fury ecu so I may add a relay for the wideband heater. I'm still in the design phase so nothing is set in stone yet.
thanks again it was greatly appreciated
Gerard
