Debate y preguntas relacionadas con el curso Cableado práctico para deportes de motor - Nivel Club
Could you provide the maker of the power supply fuse/relay block you used on your harness. I liked the compact design and would like to source one for my build
Also as others have noted the example links for the documentation are missing from the modules in the lessons
G'day Dan.
Its a GEP product, I sourced from WayTek wire. There are similar products available under the Eaton Bussman brand also. Give them a google and you'll find a supplier.
On it with the Doc, oversight on my part sorry. Need to tidy things up a little before I put them up. Will be up by the end of tomorrow :-).
