reusing oem connectors
1538 Vistas
based on where i am located in the caribbean getting the original connectors may be hard so i may need to cut them off the existing harness and join them onto the haltech harness, what is the best way to connect them, simple soldering and heat shrink?
Hi Saleem, I live in Puerto Rico and have the same problem. I use this site https://www.ksvlooms.com/
they are in Florida and ship here to the caribbean.
best. id check them out
If i am unable to source the connector is it possible to close or open barrel splice the old connectors by depinning them and running the dr25 over after?
