Hey all!
I have a practice measuring question regarding bearing clearances that I hope I can get some help with.
Say I measure the diameter at the crank rod bearing at: 2.0468" (51.988mm)
and the connecting rod big end with the bearing installed and torqued to spec at: 2.0435" (51.905mm)
Looking at these measurements, I think to myself the connecting rod with bearings installed is smaller than the crank by at least (+0.0033") or (0.083mm)
(Crank rod diameter - connecting rod diameter with bearing installed) = difference in diameter
Do I have this right? If so, then I measured 33thou smaller than the crank. I don't know of bearings that are thin enough that would fit in the connecting rod big end to ultimately fit around the crank.
So, what exactly am I doing wrong?
Thanks in advance for any and all help.
