engine component cleaning
Debate y preguntas relacionadas con el curso de Construcción Práctica de Motores
1941 Vistas
Just a curious question: Would you consider turning block upside down when cleaning out bolt holes, or other areas (aggravating certainly), to take advantage of gravity for debris to more easily fall out? Or do you think it does fine as demonstrated?
Enjoying courses!
Hello good question i do but if you have god cleaning gear and products combined with good air pressure you should be perfectly fine
Regards Ross
