help for knowledge.....
Debate y preguntas relacionadas con el curso de Construcción Práctica de Motores
1753 Vistas
is it necessary to replace the frost plug??
It's very dependent on the condition of the block. If it's showing no sign of corrosion then often not. If on the other hand the coolant passages are showing a lot of rust then it's a good idea to replace them.
