Škoda 440 crankshaft anticrack suppors
535 Vistas
Hello, I want to ask about the motor of škoda 440, to be exact about its crankshaft. I want to support its strength, but I don’t know how. The problem with this crankshaft is that it tends to snap and break due to being fastened in only 3 places, while it has 4 pistons. Thanks to that there are two conrods next to each other without bearing cap between those two. That leads to snapping after not great milage. Therefore I want to support its somehow to prevent that snapping. Do you know how?
Thanks a lot for your answer!
