SR20VE Step 9:Long Block Assembly
Debate y preguntas relacionadas con el curso de Construcción Práctica de Motores
2526 Vistas
Hi Andre,
At 45:52 min of your video on the long block assembly of the SR20VE you state there is an attached file to recheck the timing once you have rotated the crankshaft through 720 degrees. I have not found that file attached.
Regards
Francis
Apologies for that. I'll get it added but for now I've attached it below.
