Drag race boost control
Control de lanzamiento
Discusión y preguntas relacionadas con el curso Control de Lanzamiento
2596 Vistas
How can I do time based boost with m1? I can't find any time axis option on any tables.
In the production packages there isn't a specific time based option for trimming your boost. You can however trim the boost based on gear if you like.
In GPR you can trim boost based on time. It's under "race time" and you'll have to add time to the boost table axis.
Hey Chris, thanks for pointing that out. I had completely overlooked the Race Time function and you're right this can be used as a boost trim axis.
This is a pretty big oversight on my part since we actually ran a webinar specifically on the Race Time and Average Load functions: https://www.hpacademy.com/previous-webinars/044-average-load-and-race-time-functions-motec-m1/
