1995 Nissan Skyline GTST - 100% STOCK
Crear hilos
2869 Vistas
Picked up an R33 with 67k original miles
The stock RB25DET barely puts out 190rwhp and does not make steady power.
Refreshments anyone?
Ignition
- new NGK spark plugs
Fuel Delivery
- new Z32 fuel filter
- new Walbro fuel pump
Air Delivery
- new air intake
Engine
- new Greddy OX-03 oil filter
- new 10w30 oil
Exhaust
- 3" downpipe
- custom 3" Cat-less exhaust
IG Profile
@RB26.Tech
@RB26.Tech
@RB26.Tech
Car was purchased from Japanese Classics in Virginia.
https://www.japaneseclassics.com/vehicle/nissan-r33-skyline-gts25-t/
Hello, do you have the afr /lambda and boost readings from the dyno, in my experience that dyno sheet looks like the ignition is retarded a fair amount. but to make a more educated call the above information would be super helpful
Got any boost numbers? I was thinking either a hose blown off or stuck waste gate?
@ross I dont have those numbers yet but ill see if I can get them this weekend!
@Gord ill check out hoses/WG and let you know
