16 inj on motec m800
2531 Vistas
Hello guys,
The title says it all, any possible way to run 16injectors on motec m800?
Thanks
The M800 only has 8 injector drives so technically it is intended to operate up to 8 injectors. In my old drag car we ran 2 injectors in parallel off each of the secondary injector drives with great success and in the drag racing world this is quite a common technique. I'm not sure if this is officially approved by Motec though :)
