1JZ-GTE EMU Black ECU
3318 Vistas
Hi, I have a 1JZ swapped SC300 running EMU black PNP harness. I loaded up basemap, car cranks but no start. The car has spark and fuel pressure. Attached tune and datalog of cranking. Thanks in advance!
  • 1995Sc3006262Basemap-v6.emub
  • Nostartonlycranking-v6.emublog
Sorry Henry at this stage we've had no hands-on experience with the ECU Master products so it's hard to offer specific guidance. As simple first checks I'd suggest confirming the injectors are operating during cranking (use a LED test light) and if that's the case I'd check your base timing - It's also possible that the timing may be 360 degrees out (firing on the exhaust stroke). Beyond this I'd suggest you make contact with ECU Master for specific help.
