2.9 ABV vr6 turbo knock sensor set up
1777 Vistas
Hello i am completely new here so if this is in the wrong place sorry in advance ..
my question is i have a 2.9 vr6 turbo running a ecu master classic and am wanting to how i would set up the knock sensor sampling and also at what degree should i tell it to listen to as well .and what frequency the car has a knock sensor on the rear and front of the engine . another part of my question is what voltage to rpm should i set as knock engine noise . thanks in advance for any help ..
Hi Luke sorry I am not familiar with your engine or particularly with this ECU if no one else replies today I would suggest jumping on the tech support guys at ECU master for some base settings for this engine
Regards Ross
ok thanks
