2011 Camaro L99 VVT
2450 Vistas
Im working on a 2011 camaro with the L99 6.2 liter engine. I've disabled the displacement on demand should I have to mess with the variable valve timing. Also is it beneficial to disable that as well Im not real familiar with cam timing via computer.
