2017 hemi 5.7 vvt motor
694 Vistas
I need some help.. I have a 2017 Dodge 5.7 Hemi VVT motor, all stock, running on Maxxecu Race. Ive been having trouble getting timing and cam settings. (there is alot of false info out there)... I know cam is at full Adv in the rest position but what are some of the base #'s and settings to start with to get the cam to the right timing? motor does run but seems very advanced at idle and low RPM, slight knock as well. Are my base #'s set wrong?
60-2 missing tooth
36-2-2 Crank
345* BTDC trigger angle
cam offset 283.8
6* timing
