2017 Ram 2500 Cummins supported on HP Tuner software?
4735 Vistas
I'm just starting the HPA diesel tuning courses so naturally I looked at HP Tuners software but the supported vehicle list only states the gas Ram HD's for '13-'18? Is that correct?
I also looked at EFILive as well but they don't seem to have base files available to play around with for the V8.3 software yet.
The Cummins is supported by HPT and EFILive. If files aren't available for V8.3, they should still be available for 7.5. Are you tuning a 68rfe truck or an Aisin?
Hi Nick, 68RFE.
What’s your email, I can send you a 2017 68rfe stock file tmrw
Thanks I'll send you a PM - if I'm able to.
Send me a PM at EFI's forum - 20172500
Thanks,
You also have Warp tuning software and I believe Raceme.
Yeah I'm aware of Warp Tuning. Same 4everlearning from CF?
