2jz vvti M1 trigger settings
2102 Vistas
hello! can somebody help me debug my m1 trigger settings for 2jz for now i get message that there is pattern lock but cant achieve cycle lock.
in attachments i have config file and input scope maybe someone could tell whats wrong?
  • 012_Tuning-Base-V2-6734.zip
There is no Resource for "Engine Synchronisation Resource" defined. I bet you meant for that to be UDig2 which you have assigned to Inlet Cam Bank 1 Position Resource. Use All Calibrate, tick the "Setup" tag then search for "Sync". Once this is selected, you will find more options under the Engine Synchronisation Parameters pane in the Initial Setup->Ref Sync tab. These will need to be configured appropriately, particulary the Engine Synchronisation Pin Hysteresis.
