2jzge link atom trigger issues
2020 Vistas
The Atom does not have a built in trigger scope. But do you have a scope that you can log the triggers with? If so do that and upload a picture of the trigger sequence here.
worked out gotta press entre when doing trigger offset and firgured where my massive are leak is? i dont have acess to a scope is there any cheapish ones available?
Hi David,
From your similar post on the Link forum that I answered the other day I didnt get the impression that you had a trigger issue at all.
What makes you think you actually have a trigger problem?
