Accesstuner race
2024 Vistas
Anyone here knows how to work with the accesstuner race?
Yes is there something I can help you with? What are you looking to do?
Hi yes i have a 2005 sti on sd with 1000cc inj and i'm making a map myself, whats the most important thing that has to be changed to tune the car, cause i see alot of changes that you can do with the atr but don't know if i should be changing all of them, i just try to set the ve the ign table, I have a aem tru boost so i don't think i should mess with the wastegate duty cycle, or do i?
And i can't get the idle to set fast, when i press the clutch to slow down or brake the car almost stalls, ant takes a little time to get back to idle
