ACES Jackpot EFI Cam Trigger Settings
1499 Vistas
Hello, I am working on tuning a gen 4 5.3 LS with a 58x Crank reluctor and a 4x cam wheel. I am working on the ACES Jackpot EFI software and and there are some settings I am having trouble understanding related to the cam triggering. It asks for: 1. First Circle CAM edges 2. 2nd Circle CAM edges Then it asks for 1. First Circle CAM Last Edge 2. Second Circle CAM Last Edge I reached out to the customer support from ACES to no avail I am hoping you may have either encountered something similar or could recommend what values I should use here. Thanks in advance.
I'm sorry I've got absolutely zero experience on this platform so it's difficult to add much support. Given that you're working with such a common platform I'd imagine a call or email to their tech support should have you sorted very quickly.
