Adding additional AVI’s on Haltech sport 2000
2486 Vistas
so I have a customer who is running a Haltech platinum sport 2000 with a brand new Tweakd engine harness. Tweakd provided a pinout for all the inputs and outputs, but one issue I’m running in to is the number of inputs. Some of the analog inputs on the harness are said to be AVI 11, 8, 9 etc.... but when I go in to the haltech and go to inputs, it only shows AVI 1-7. I cannot figure out a way to acces the additional inputs. Is this not possible on the sport 2000? Should I just repin some of the inputs on the harness to just use 1-7?
A quick google search suggests the Platinum sport only offers 7 AVIs so this is probably a harness that is suitable for different ECUs with more I/O. Re-pin them as you've suggested to use the available inputs.
