Aem failsafe gauge tacho signal wire
2078 Vistas
Hi im Craig from northern Ireland this is my first post but getting some great info off the forum .
My problem is i have a aem failsafe gauge for my boost and afr but my car has canbus to control the tacho so there is no signal wire to connect to. Is there a way of getting a tacho signal on a canbus vehicle for the aem failsafe to work fully? Would like it all working as it also data logs ..
Thanks Craig
I've never tried it, but you probably need to use a tach adapter such as the one Autometer sells. https://www.americanmuscle.com/autometer-tachadapter-9612-install.html
Thanks I'll look into that and see of its would any use in my case
