AEM Tuner trigger offset
1556 Vistas
i have RB25DET Neo Hitachi cas on AEM s2 6620 with AEM COP 24 tooth trigger disk and it triggers on exhaust stroke i tried to do offset but i don't know how to set it ?! do i put 180 degree on ignition sync on red circle in the attachment pic ?
If I understand that screenshot correctly, try 12. The field is for teeth, not degrees
