Aem uego 30-4110 wideband logging setup
2973 Vistas
Hey guys been trying for years to get the aem wideband to log correctly with the link g4 but get cruise close and wot is miles out can any one please help me out?!?!
It sounds like you may have a ground offset effecting the accuracy of your wideband measurements. I haven't had much to do with the AEM widebands but if you can set the wideband up to output a constant 0.5 volts and then 4.5 volts you can see what the Link ECU is receiving. This then let's you set up the offset correctly so the AFR is accurate.
