Air temperature compensation tabe
2169 Vistas
I am wondering if the haltech platinum PRO automatically compensate for the air temperature (similar to the ELITE) or I need to have Air temperature correction compensation table.
Thanks
If you're using VE mode then the air temp is automatically accounted for in the fuel calculation. There is still a manual air temp comp table that can be used if needed to account for any discrepancy caused by auto air temp compensation. If this table is zero then the air temp is handled entirely in the fuel calc.
Thank you for your immediate reply Andre.
