Base map for M1 M150 Subaru STI
2244 Vistas
Hi Andre and folks
Can anyone provide me with a base calibration file for the M150 (fuel and ignition can be set to zero) for a Subaru Impreza GRB STI year 2009 / 2010
or a GDB STI 2005 - 2006 ?
Your help is greatly appreciated.
Best regards
Dynodom
Hi,
Dependant on the AVCS (Single or Dual) used on your engine, you will need to use either Mode 22 (Subaru EJ207AVCS) or Mode 27 (Subaru FA20D) as the reference mode, the help for these engines is comprehensive and gives a baseline for the settings for the cam position sensors, as well as the ref and sync sensors.
BlackRex
Thank you for your help, I try my way through the config, will post back here when done.
Best regards
D
Let me know if you need any help, I have a bit of knowledge about the M1's and running them on Subaru's. The car in my profile in running one.
