Beginning tuner. I have finished the practical reflash tuning class. I am following the "HP Tuners GM Gen III/IV LS - Basic" working example using HPTuners(HPT) just like the instructor. I have downloaded my factory base tune, and now following the steps to setup/modify the base tune before I begin the road testing. Some of my HPT tables are different from the training video, some options are not there. Is this because my newer version of HPT has been changed. Do I need to just make the changes that look the same and move on? Worried I might make a mistake.
I apologise for the slow reply here. The first thing to check is that your VCM editor is in 'advanced' mode. Go to Edit - View - Advanced. If you're in basic mode then some tables and parameters will be hidden. Beyond this you will also see differences in the available tabvles/parameters if your ECM is different to the one we used in the example. I hope that helps.
