Billet Atomizer Deadtime
4253 Vistas
Hi all,
can anyone confirm that the attached chart is correct for the Billet Atomizer 3 160pph?
I tried to contact them several times but didnt get an answer :-(
Thank you
Ok, i think i finally found them.
I've yet to find data that's reliable or believable on the billet atomizer injectors. I've also contacted them directly and I don't believe they have data. The numbers in the attachment you added seem pretty light for such a large injector - I've yet to see any injector that has a deadtime in the 0.2 ms range at 14 volts.
Thats why i was very critical. But now they have sent me some values and they fit to the ones that i have found.
