Bosch 2200 cc Injector Data
3333 Vistas
Anyone have data on these injectors? I am setting up a basemap for a b18 on hondata. Thank You
I'd ask the distributor you bought them from. Most of the Bosch 210 data out there is still mired in the ID/FIC profile copying fiasco so I wont post it up here as gospel, and make sure you do your research and contrast and compare. That said just look up 'Bosch 210 injector data' in the googlator. Also Grams Performance has a pretty verbose chart that may or may not (I honestly cant remember) be a copy of old ID2000 injector data.
