Bosch Injector Info
2101 Vistas
Trying to gather the injector data for some Bosch 2200 injectors model #280158821 and everywhere I look there seems to be different dead times listed. Is this normal due to different testing equipment? If anyone has the information on these injectors it would be greatly appreciated. Fuel setups e85 with 43.5psi base fuel pressure and a rising rate regulator.
