building a 7afte engine
2924 Vistas
Hi,
guys I am working on this toyota trueno AE85 and planing to build a 7A FTE engine.
Have already bought a 7AFE stock engine.
Planing on introducing a TD04 for the turbo.
Need your opinion on pistons and the aftermarket ecu I should go with.
Really this comes down to personal choice and availability of parts. Personally I tend to use JE, Wiseco and CP and have always had good results with those products. As for the ECUs, this comes down to your budget and what functionality you need. You'd probably do well to choose one of the ECUs that we use for our courses since then you'll have access to a huge library of material to help you with the tuning.
