Hi guys
so i have a bmw e36 with link g4+
I wonder if there is a way to explain the burble tune I just cannot figure it out
any help
Increase the fuel in the over-run areas (low manifold pressure/ closed throttle / low mass flow -- but engine speed say 1000 RPM or more above idle). Also try retarding the timing in this same area. If the ECU has DFCO (deceleration fuel cut-off) which completely disables the injectors, you will need to disable this feature.
