calibration the factory sensors in motec ECU manegar
2847 Vistas
what is the best way of calibration the factory sensors if we don't have data sheet or information about the sensors do l leave it as predefined table that motec provide ? or I make new custom table ?
You'll need to make a custom table if Motec cannot give you any base calibration information.
Most of the sensors would be OEM anyway, like bosch, delphi, denso, delco etc.
You could always create a test cell/lab and heat up the water temp for example from 30-110c and take your own readings for the sensors and input them in.
We find that many of the temp sensors that are used by OE manufacturers share a similar calibration so often you can utilise a common Bosch NTC temp calibration. Obviously it's always advisable to check that the readings actually make sense rather than blindly believing them. If you don't have a calibration for a given sensor and it doesn't aline with a generic calibration then you can also often swap the sensor out for an aftermarket one with a known calibration. I'd also talk to your MoTeC dealer about getting an unusual sensor calibrated for you.
