Hard to know what section to put this in
I have a Hayabusa powered landspeed bike , NA , on Petrol ( gas if you use that term ) i am using 4 separate exhausts , 2 are fitted with a venturi effect tubes and check valve ( see pictures ).
My question is how much crankcase vacuum is “ good” and how much is too much , i have a MAP sensor measuring the crankcase , so will know when and ( if) i am getting the system to work
the bike is 4 metres long ,i sit feet forward , it has a centre hub steering front wheel —- but that’s another post
Have you read this article:
http://nutterracingengines.com/racing_oil_pumps/crankcase_vacuum_facts.html
thanks , good article
answers my questions.
