Crankcase sensor
2740 Vistas
hey guys just wondering what sensors every one is using to check crank case pressure
I have used a MAP sensor (dry sumped engines, which pull crankcase vacuum), but any absolute pressure sensor that can read over one bar (assuming you expect to have positive crank case pressure) will do.
