Denso blue color RX-8 Fuel Injectors 195500-4460 Latency/Dead time
3374 Vistas
Hello to all fellow HP members,
i would like your help regarding the latency (lag time, dead time, offset or delay) of the DENSO fuel injectors (blue color) with p/n 195500-4460.
Could someone advise me the Dead Time (ms) vs Volts (V) curve, in order to calibrate them accurately in the Megasquirt ECU.
Thank you in advance.
Best Regards
Kyriakos
If you can't find them elsewhere you can probably download the adaptronic software and pull them from the dead time tables there.
After a lot of searching i have managed to find the attached table specific for the blue injectors.
