Drop in injectors for the 2JZGTE
2467 Vistas
I am looking for a set of 650cc - 800cc drop injectors for my 2JZGTE. I ve used Power Enterprise injectors (Denso) in the past and had a good experience. I just want something that will fit into the stock rail and I will only be running it on gasoline. I dont seem to find these original injectors anymore, although there is something similar on ebay from a vendor called KSM motorsports, however I am not sure how reliable that is. Any recommendation would be much appreciated?
https://www.ebay.com/itm/6-X-fit-DENSO-650cc-FUEL-INJECTORS-for-TOYOTA-SUPRA-JZA80-2JZGTE-2JZ-SIDE-FEED-/142476458561
Check out like Injector Dynamics
