Dynapack hub dyno logging
2431 Vistas
Hi all,
Can any dynapack hub dyno owners tell me if its possible to log and save to file from OEM OBD2 in .csv format?
Thanks in advance!
If you have the ODB2 interface, then channels from OBD2 are included in the channel list that is logged. You can export the logged channels in .CSV format. I've never tried this exact combination (infact, I've only used ODB2 on one car, I use the CAN interface all the time with stand-alone ECU), but I would say the answer to your question is: Yes, you can do that.
Hi David, can you give me a little more specifics on how you go about exporting logged channels to file be it can or obd2 ?
Use Shift-F4 to bring up the "Mapping Aid" view. You can setup the data / columns you want there, and use Export, or Export All Data.
Is that sufficient?
Hi David, thanks a lot for that...i will relay to the dyno operator and get back to you if needed. Really appreciate your input, thanks again!
