Dyno Dynamics correction factors
4074 Vistas
What formula does DD use for calculating fly hp from whp in shoot44 mode?
What corrections are used in ATMC2? This is not DIN or SAE.
no DD users on the forum?
I do have a DD 450ds .but can not answer your questions. I think that a more Dyno dynamic tech questions. I been using mostly normall mode with diffrent ramp rate for diffrent aplication.
I own a 650KW DD.
If memory serves me right, it is a simple 1.15 correction factor.
