ECU Black Ignition timing at idle
1323 Vistas
Hi,
I have an ECU Black on a lotus Exige. At idle once the motor is wormed up my timing is at 1deg BTDC. The engine idles smooth. I believe it should be around 5deg BTDC. Can anyone help me with this adjustment.
