Ecu crimps civic
694 Vistas
I’m trying to find these mk8 civic ecu plug crimps. Finding it really hard to find them. I will try to load a pic of them tonight.
if anyone has any idea where to get them from please point me in the direction for me to hunt
Did you reach out to Tegiwa Imports or try the group I linked previously? I will paste the previous reply below again just in case you missed it from your other thread.
"Brandon here thinks they might be TYCO HT-030051
https://www.tegiwaimports.com/haltech-ecu-pins-8-32-pin-tyco-range.html
Tegiwa Imposrts in the UK possibly stock them.
Outside of that this is a great podcast to listen to as Ryan does touch on his own process for identifying OEM connectors in Hondas - https://www.hpacademy.com/blog/049-turning-a-wiring-side-hustle-into-big-business-podcast/
This 'Automotive Connector Identification' Facebook group is also super helpful - https://www.facebook.com/groups/4359499570789592 "
I had checked back on the other thread but had not seen a reply so I had thought it might have been missed due to being posted in the wrong area. I will check the links you have shown. Thank you
No worries at all, hope it helps. You are not alone in struggling with connector identification, it's a bit of a minefield at times but if Tegiwa can't get you sorted I know that Facebook group will for sure.
