ECU Master Black no pump run or injector/ spark pulse during crank.
1406 Vistas
Hi Just installed a black into a clio with ITBs .
Got rpm signal on dash and all sensors seem good .
Done the test to check spark injectors pump fans etc and all good.
when cranking i have no injector pulse or spark and no pump running during the crank.
Pump primes when i first turn on ignition and have 12v at coil and injectors.
What am i missing?
Perhaps a sync (cam) signal. Is it configured to do sychronous injection, or batch-fire? Is the ignition individual coils, or wasted spark?
It's unlikely some can guess what you may have mis-configured. Usually uploading a copy of the ECU configuration / tune is required for any real help. You might have to put the file into a .zip file for the forum software to allow uploading.
