Hello!
I wanted to know if you have had the experience of calibrating the Deatschwerks 1700cc injectors on a 2017 Infiniti Q60 with a VR30DDTT engine with the Ecutek program. The data provided by the manufacturer of the injectors are not consistent with the adjustment tables of the ECU program, or at least I have not been able to. Is there any calculation or conversion that can be used to put in the correct data so that the ECU recognizes these new injectors? The P/N of injectors 19S-05-1700-6 and the manufacturer indicate that to calibrate Infiniti I must use Ford Ecoboost calibration data.
[img="blob:https://www.hpacademy.com/bbb77f96-06f3-47fa-8623-544509ed09c3" alt="" alt="" ]
