Ecutek racerom gt86/brz/frs flame map tune
4278 Vistas
Hi,
I do have Ecutek RaceRom with custom maps, licence and software, tuned with Ecutek and Turbo’d.
im reaching out to pick peoples brains to see if they have experience with Ecutek and knows how to properly turn off fuel cut overrun while retarding spark events while richening the fuel mixture, aligning the maps to perform at the same time so we get backfires and flames on decel and also at idle.
Also does anyone have experience where they’ve achieved backfires through custom maps that activate on launch control? This is helpful to spool the turbo on a turbo application.
Thanks in advance, highly appreciate it. This could clear up some confusion that other Ecutek users experience for the 86 platform.
Bump
Bump
Hi Blake,
I have done flames on these cars. What timing and fueling are you targeting?
Hey mate, what adjustments can you give and test to give my 86 flames?
