Emu Black problem
2380 Vistas
Hello looking for some help with emu black
I got my car started but the timing was a little of so i made few changes at crank pulley and firmware update and now the ecu stays powered ignition of and i found 12v at idle valve & boost selenoid but if i run test output hbridge1a witch is for idle with ignition off then the ecu is stop working. And my egt temps are going down when pushing gas pedal. Is it possible to be a damaged ecu ?
Hristo,
Given the breadth of concerns with the ECU, I would contact your ECUMaster dealer for support to start.
If they determine the ECU is OK, hopefully they'll have some suggestions on your other concerns too.
If they aren't able to resolve your concerns, please let us know and we can try to help with one thing at a time.
Please let us know how it goes.
i solve the problem .... just take out the +12v source and connect it to switched so when i switch off ignition to cut power to ecu.
