Eurodyne Maestro 7 Base Map Files
3790 Vistas
Is anyone able to provide examples of the base maps Eurodyne provide for the 2L TFSI engine EA113/AXX?
A look at the MAF/injector/TB/Intake options would be ideal thanks.
I've sent an email asking with 0 reply
cheers,
Martin
Anyone?
i might have them. but you need an engine code to get the correct map
Chris,
thanks for the reply mate appreciate it but I've decided to rip out everything VW and start from scratch with a rywire PMU & open harness, ECUMaster EMUblack and their ADU.
